Article ID : 00195664 / Last Modified : 16/08/2021Print
    Adjusting the Picture setting on my LCD TV
    IMPORTANT: This solution applies to BRAVIA TVs other than Android TVs. For Android TVs, refer to Adjusting the Picture setting on my Android TV.
    You can adjust the following with picture adjustment settings.
    Press HOME → Settings → System Settings or Display → Picture
    NOTE: The availability of the function to adjust depends on the model of the TV.
    Setting items
    Overview
    Picture Mode
    Set a picture mode.
    Reset
    Reset all Picture settings except Picture Mode and Intelligent Picture Plus to the default settings.
    Brightness
    Brighten or darken the picture.
    Brightness
    Backlight
    Adjust the backlight luminance.
    Reducing the brightness of the screen reduces power consumption.
    Picture/Contrast
    Adjust the picture contrast.
    Picture/Contrast
    Black level
    Adjust the black level of the picture.
    Color
    Adjust the colour saturation level.
    Color
    Hue
    Adjust the green and red tones.
    Color Temperature
    Adjust the colour temperature or the whiteness of the picture.
    Sharpness
    Adjust the picture details.
    Sharpness
    Reality Creation
    Adjust fineness and noise for a realistic picture.
    Resolution: Adjust fineness and clarity. Select Manual from Reality Creation to adjust the Resolution.
    Reality Creation
    Mastered in 4K
    Optimize picture quality for Blu-ray Discs mastered in 4K. Applies to 1080/24p signals only.
    Noise Reduction
    Reduce the picture noise (grainy picture) in a weak broadcast signal.
    Random noise reduction
    Reduce repetitive random noise.
    MPEG Noise Reduction
    Reduce the picture noise in MPEG-compressed video.
    Digital noise reduction
    Reduce video compression noise.
    Motionflow
    Refine moving images.
    CineMotion/Cinema Drive/Film mode
    Provide improved picture movement when playing BD (Blu-ray Disc), DVD, or VCR images taken on film. Select Auto to reproduce original film-based content as is.
    NOTE: If the image contains irregular signals or too much noise, CineMotion/Cinema Drive/Film mode is automatically turned off even if Auto is selected.
    Advanced Settings
    Set detailed Picture settings such as Gamma or Live Color.
    Intelligent Picture Plus Set-up
    Intelligent Picture Plus: Enhance picture quality according to preferred settings, channel, or video input.
    Signal Level Indicator: When On is selected, the signal level bar is displayed when you select an analogue channel or video input.
    Picture Optimization: This allows you to enhance the picture to your preferred settings.
