Article ID : 00237075 / Last Modified : 19/01/2026Print
    The volume in Netflix is lower after updating to Android™ 9 Pie
    When the Dolby Dynamic Range is set to be Compressed, the volume will increase.
    Perform the following while watching Netflix:
    1. Press the Quick Settings button or ACTION MENU button on the remote control.
    2. Select  Settings.
    3. Select Display & SoundSoundVolume levelDolby Dynamic RangeCompressed.
    NOTE: For more about Dolby Dynamic Range, refer to: What is Dolby Dynamic Range and how is it set?
