Article ID : 00247125 / Last Modified : 19/01/2026Print
Gaming Console
    Select a cable type.
    Select a cable type to connect the TV and the Gaming console. The quality of the video and streaming sound can be paired depending on the features or specifications of each cable.
    The cables that can be used also depend on the Gaming console. For details, refer to the manual of your Gaming console.
