Article ID : 00256135 / Last Modified : 28/05/2026Print
    What is the Accessibility Shortcut and how is it used?
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article.
    About the Accessibility Shortcut
    You can quickly access your favorite accessibility function by pressing and holding the MUTE button on your TV remote control for more than 5 seconds. By default, this opens the TalkBack function.
    Note: If your TV displays a Use Accessibility Shortcut? message, press the Enter button to proceed.
    Pressing the MUTE button on the remote control to activate the Talkback function.
    Accessibility functions you can set as your preferred shortcut
    • TalkBack
    • Switch Access
    • Text Magnification
    • Screen Reader
    Note: The accessibility functions you can choose from may differ by model.
    How to configure the Accessibility Shortcut
    1. On the remote control, press the Quick Settings (spanner or gear) button and select Settings.
    2. The next steps will depend on your TV menu options:
      • Select AccessibilityAccessibility shortcutShortcut service.
      • Select SystemAccessibilityAccessibility shortcutShortcut service.
    3. Select your preferred accessibility function.
    Notes:
    • Depending on the model, the Accessibility Shortcut option is not available during the initial TV setup.
    • Depending on the model, when the TalkBack feature is set to ON, Edit in Quick Settings cannot be used.
    • For eARC supported models, when the TalkBack is activated, eARC mode will be Off.
