Article ID : 00274129 / Last Modified : 28/05/2026Print
    Voice search (Google Assistant)
    IMPORTANT: This article applies only to the specific products and operating systems. For details, check the Applicable Products and Categories section of this article.
    Voice search
    The voice search function can help you find content you are looking for by listening to your spoken search words. In order to use the voice search function, an Internet connection and to sign-in to a Google account are necessary.
    When you are using an app, search results in the app will be displayed on your TV screen. Below is an example of an app where the voice search function can be used:
    • YouTube™: You can search contents available in YouTube.
    Note: The search results are from YouTube content when the app you use has not been supported by voice search function.
    How to use the voice search function
    1. On your remote control, press the MIC or Google Assistant button.
    2. At the top of your TV remote control, speak into the microphone (such as a movie title) while holding the MIC or Google Assistant button.
    Google Assistant
    If your TV has Google Assistant, You can also ask Google Assistant to play your favorite movie or TV show, check the score of your favorite team, control your TV, dim the lights and more, all using just your voice.
    Note: Whether the TV supports Google Assistant varies depending on your region or language. For details, refer to the Supported countries/regions/languages and how to use Google Assistant article.
    Attributions
    Google, Google TV, YouTube and Android TV are trademarks of Google LLC.
