Article ID : 00275350 / Last Modified : 09/03/2022Print
    New software update available: solution for blurred or pixelated TV picture (February 2022)
    Occasional pixelation or blurring solved
    In February 2022, Sony has begun rolling out a new software update that solves occasional pixelation or blurring (also known as macro-blocking) when watching TV with a CI+ module. If you can sometimes see individual square pixels on your TV screen, please follow the steps in this article to get the new software update.
    Note: The software update is rolled out gradually and its exact timing can differ depending on the TV model.
    Step 1: Check the applicable TV models
    The pixelation issue might occur on the following TV models, especially if you use a CI+ module smartcard to watch TV. Make sure your TV series is included in the list below:
    • 2021 Sony Android TVs: X80J, X81J, X82J, X85J, X89J, X90J, X92J, X93J, X94J, X95J, A80J, A83J, A84J, A90J and Z9J Series
    • 2020 Sony Android TVs: XH90 and XH92 Series
    Step 2: Update your TV software
    You will get the update automatically if the Automatically check for update setting is enabled on your TV.
    TIP: You can receive this software update as soon as it's available for your model by following the steps below on your TV:
    Go to SettingsSystemAboutSystem Software updateSoftware update.
    Alternatively, you can download the update using a USB flash drive
