With the flexible and configurable Eco Dashboard, energy saving settings can now be centrally managed. You can easily customize energy saving settings for your TV usage, viewing environment, and the content you are watching, all in one place.
Notes:
- This feature is only available on certain Google™/Android™ TV models after software update. Make sure that your TV is updated to the latest software version and refer to this article to learn How to perform software update.
- Access Eco dashboard by pressing the Quick Settings (
or
) button on the remote control. If Eco dashboard does not appear in the menu even though your TV is on the latest software version, it would mean your TV does not support this feature.
