Article ID : 00413573 / Last Modified : 13/10/2026Print
    Color reflections appear on the TV screen surface
    IMPORTANT: This article applies only to specific products. Check the Applicable Products and Categories section of this article for details.
    The screen reflection appears as rainbow-colored stripes. Is this normal?
    Yes, it is normal to see certain reflections on the screen. When viewing the screen from a close distance and at an angle, striped, rainbow-like reflections may be visible on the screen.
    At a normal viewing distance, the striped reflections become less noticeable, allowing you to enjoy the displayed images comfortably.
    Why do striped reflections appear on the screen?
    Due to the optical design that achieves high brightness and a wide color gamut, light interference inside the panel (within the backlight) causes the reflections to appear as stripes.
