Article ID : 00355842 / Last Modified : 11/06/2025Print
Specifications for REON 5
    Power source
    DC 3.7 V: Built-in lithium-ion rechargeable battery
    DC 5 V: When charged using USB
    Operating temperature range
    5°C to 40°C
    Dimensions (w/h/d)
    RNPK-5/RNPK-5T
    Approx. 125 mm × 45 mm × 170 mm (when the unit and the air vent cover (long) are attached to the neckband, including
    the band)
    Approx. 55 mm × 23 mm × 117 mm (unit only)
    Mass
    RNPK-5/RNPK-5T
    Approx. 160 g (when the unit and the air vent cover (long) are attached to the neckband)
    Approx. 116 g (unit only)
    Communication specification
    Communication system:
    Bluetooth 5.0 Low Energy
    Output:
    Bluetooth Specification Power Class 2
    Frequency band:
    2.4 GHz band (2.4000 GHz to 2.4835 GHz)
    External interface
    USB Type-C®
    System requirements for battery charge using USB
    USB AC adaptor
    A commercially available USB AC adaptor capable of supplying an output current of 1 A (1 000 mA) or more
