Article ID : 00399942 / Last Modified : 11/05/2026Print
    Are there any precautions I should take when using the neckband of REON POCKET?
    If you have used sunscreen or insect-repellent spray around your neck, after using the neckband, be sure to wipe it gently with a soft cloth.
    Also, do not put any pressure on the neckband when you use a backpack or baby carrier, etc. (and also when you lean against the back of a chair, etc.)
