Turn the headphones off and on again, then check to see if the Power indicator flashes.
Note: The location and color of the power indicator differs depending on the product. For details, refer to the manual supplied with the product.
- WH-1000XM4
- WI-C400
- The indicator flashes
- The headphones turn on normally.
- The indicator flashes blue and red alternately or it flashes blue twice
- The headphones are in the Bluetooth pairing mode.
Note: When you pair the headphones with a device for the first time after purchase or after initializing the headphones, the headphones enter pairing mode automatically. - The indicator does not flash or light up
- Go to the next troubleshooting step.
- WH-1000XM4
Start charging the headphones, then check to see if the indicator lights up.
- The indicator lights up
- The headphones are in the process of charging. Continue charging and go to the next troubleshooting step.
- The indicator does not light up
- There may be a problem with charging. Refer to the The headphones do not charge article.
Reset the headphones.
WI-C400 How to reset
Note: For details on how to reset the headphones, refer to your model's Help Guide.
WH-1000XM4 How to reset- The headphones turn on
- The issue may have been caused by a temporary malfunction.
- The headphones do not turn on
Initialize the headphones.
Notes:- After initialization, the headphones will return to the factory settings and all Bluetooth pairing information will be deleted.
- The method of initializing the headphones differs depending on the model. For details, refer to the headphones Help Guide.
- The headphones may be malfunctioning, and service may be required.
