Are you using the headset in crowded places?
Yes, I am.
If you use the headset in crowded places (on congested trains, congested roads at rush hour, etc.), the people surrounding you may interrupt Bluetooth communications, causing sound skipping or noise. If the issue does not occur when using the headset at home or in another non-crowded place, there are no issues with the headset.
No, I am not.
