Article ID : 00285297 / Last Modified : 20/01/2026Print
Sound skips when using the headphones. (WF-C500)
    Before you start
    Using the headphones in a crowded place such as on a train or busy road, nearby devices may interrupt Bluetooth communication and cause sound interruptions, interference, or noise. If the issue does not occur at home or somewhere with fewer nearby devices, then it is Bluetooth communication interference causing the issue, and not headphones.
    1. Switch the sound quality mode to Priority on Stable Connection.
      1. Open the Sony | Headphones Connect app, and connect the headphones and the device via Bluetooth.
      2. In the Sound tab, set the Bluetooth Connection Quality to Priority on Stable Connection.
      The issue is resolved
      The headphones setting was the cause of the issue.
      The issue is not resolved
    2. Stop the Bluetooth connection to any device other than the headphones.
      The sound can skip when another device (smartwatch etc.) is also connected.
    3. Close all apps except the one you are currently using.
      The sound can skip when multiple apps are open at one time.
    4. Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
    5. Reset the headphones.
      Visit the Help Guide or view the How to reset video:
    6. Initialize the headphones.
      Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Visit the Help Guide or view the How to initialize video:
    Go to the Headphones Troubleshooting Guide
