The headphones do not turn on. (LinkBuds S)
Follow these steps to troubleshoot when the headphones do not turn on:
- Select your issue details:
- Check if the Google Assistant or Amazon Alexa is set to the headphones.
Note: When the Service Link feature is turned on using the Sony | Headphones Connect app, only the Right side can be used alone. -
Check the touch sensor control function or Voice Assistant function according to the way you use the headphones:
When the Google Assistant or Amazon Alexa is set to the headphones, only the side with the touch sensor control function set to Playback control can be used alone.
- If you want to use either side of the headphones: Set the touch sensor control function of the desired side to Playback control. Follow these steps to set the touch sensor control function to Playback control:
- Open the Sony | Headphones Connect app.
- In the System tab, select
(Settings) on the right side of the Change the touch sensor function menu.
- Select the side you want to use alone, either L (Left) or R (Right), and set the Function to Playback control.
Note: When you assign Playback control to both sides, full functionality is only available on the Right side.
- If you want to use both units alone respectively: Set the Voice Assistant function to Voice Assist Function of Mobile Device. With this setting, either side of the headphones can be used alone.
- Select
(down arrow) on the right side of the Voice Assistant menu.
- Select Voice Assist Function of Mobile Device or Do not use.
- After changing the settings, the headphones turn on.
- The headphones settings were the cause of the issue.
- The headphones do not turn on.
- Go to step 4.
Clean the charging ports of the headphones, and check the indicator of the charging case.
Clean the headphones and charging ports, set the headphones to the charging case, and check the status of indicator on the charging case. For details on how to clean the headphones, refer to the How to care for the headphones article.
Note: When cleaning, do not use compressed air to remove dust as this can cause dust to get into the microphone or sound outlet holes, leading to malfunction.- The indicator lights up in green or orange
The headphones are fully charged. Go to step 5.- The indicator lights up in green or orange
The abnormal temperature or some other issue prevented charging. Go to step 10.- The indicator does not light up
The remaining battery of the headphones is 1% or lower. Go to step 8.
- Wear the headphones and check if you can hear the voice guidance.
Play music on the connected device, and check if you can hear the sound.
Pair and connect the headphones and the device via Bluetooth, and check if you can hear the sound on the connected device.
- I can hear the sound on the connected device.
- The issue has been resolved by charging or changing the settings.
- I cannot hear the sound on the connected device.
- Pairing may have not completed. Refer to the appropriate article to connect with the device:
- For Android: Pairing and connecting with an Android smartphone
- For iPhones: Pairing and connecting with an iPhone
- For other devices: How to pair Bluetooth headphones with a Bluetooth source device
- Check the Voice Guidance settings:
- In the System tab, check the Notification & Voice Guide setting.
- Try the following procedure, and check if the headphones turn on.
- Make sure that the earbud tips are properly attached to the headphones.
- Set the headphones into the charging case, and start charging.
Note: Make sure that the left and right headset units are inserted into the correct sides. - Remove the headphones from the charging case, and check if the indicator lights up in green or orange.
- The headphones turn on.
- The issue may have been caused by the way the ear fitting supporters were attached or placed into the charging case.
- Go to the next troubleshooting step.
Refer to the Help Guide or view the How to reset video:
- The issue is resolved.
- The issue may have been caused by a temporary malfunction of the headphones.
- The issue is not resolved.
Initialize the headphones.
Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.Refer to the Help Guide or view the How to initialize video:
- The headphones may be malfunctioning, and service may be required.
