Article ID : 00253599 / Last Modified : 04/12/2024Print
    How to wear my headset so the earbuds do not fall out of my ears. (WF-XB700)
    1. Insert the headset units into both ears.
      Put the unit with the (left) mark on your left ear and the unit with the (right) mark on your right ear. The left unit has a tactile dot.
      Illustration indicating the location of the tactile dot (A) on the left unit
      1. Tactile dot
    2. Twist the headset to slide the earbud firmly into your ear.
      Hint: The earbud will be easier to slide into your ear if you pull up on the top of the ear lightly while twisting the headset.
    If the earbuds do not fit your ears
    Medium (M-sized) hybrid silicone rubber earbuds are pre-attached to your left and right headset at the time of purchase.
    If the earbuds tend to come off or you feel that there is insufficient low frequency sound and a difference in volume between the left and right units, change the earbuds to another size to comfortably and snugly fit your left and right ears.
    Tip: See if a different sized earbud on each earphone solves the issue. Try variations such as a Small (S-sized) earbud on one headset and an M-sized earbud on the other.
    You can also watch a video on how to replace earbuds and wear your headset correctly.
