Article ID : 00264481 / Last Modified : 20/01/2026Print
    Note on wearing headphones for a long period of time
    Wearing In-Ear headphones or Truly Wireless headphones for a long time may cause itchiness or ear inflammation. If you feel such symptoms, stop using the headphones immediately, and consult a doctor.
    We recommend that you:
    • remove your headphones regularly, especially when you use them for extended periods of time.
    • keep your earbuds clean from dust and dirt.
    For how to care for the headphones, refer to the product manual, Help Guide or support website.
