The headphones do not charge. (WF-1000XM4)
Follow these steps to troubleshoot why the headphones do not charge:
Select the way you charge.
Place the charging case on the wireless charging pad properly.
Close the lid of the charging case and place it on the wireless charging pad with the SONY logo of the charging case facing upward.
Note: If the charging case becomes misaligned with the wireless charging pad, charging may slow down or stop, or the charging case may become hot. For details on how to properly set the charging case on the charging pad, refer to the charging pad manual.
- The issue is resolved
- The issue may have been caused by the position of the charging case or wireless charging pad.
- The issue is not resolved
- Go to step 3.
Place the charging case on the wireless charging pad, and check the indicator of the charging case.
Leave the charging case in a place with an ambient temperature between 15 °C and 35 °C (59 °F - 95 °F), and try charging again.
- The issue may have been caused by the ambient temperature being too high or too low.
- Go to step 11.
Using the supplied USB cable, connect the charging case to a USB AC adaptor or computer, and check if the charging can be completed.
- The charging can be completed
- If you use the wireless charging pad, remove anything attached to the charging case, such as covers. If the issue is still not resolved, the cause may have been the wireless charging pad. Consult the manufacturer of the wireless charging pad.
- The charging cannot be completed
- Go to step 6.
Clean the charging port of the headphones, and check the indicator of the charging case.
Clean the headphones and charging ports, set the headphones into the charging case, and check the status of indicator on the charging case. For details on how to clean the headphones, refer to the How to care for the headphones article.
Note: When cleaning, do not use compressed air to remove dust as this can cause dust to get into the microphone or sound outlet holes, leading to malfunction.- The indicator lights up in green for about 3 seconds when the headphones are stored in the charging case
The headphones are fully charged. Wear the headphones, connect to a device via Bluetooth, and check if you can hear the sound from the connected device.
If the sound cannot be heard, refer to the There is no sound, or sound is only heard from one side of the headphones article.- The indicator lights up in green for about 6 seconds when the lid is opened or closed
If the sound cannot be heard, refer to the There is no sound, or sound is only heard from one side of the headphones article.- The indicator lights up in orange for about 3 seconds when the headphones are stored in the charging case
Go to step 7.- The indicator lights up in orange for about 6 seconds when the lid is opened or closed
Go to step 7.- The indicator does not light when the headphones are stored in the charging case
Go to step 8.- The indicator flashes in red when the lid is opened or closed
Go to step 8.
Set the headphones to the charging case, connect the charging case using the supplied USB Type-C cable, and check if the charging can be completed.
Note: Clean the charging port before charging.- The charging can be completed
- The charging port of the charging case may have been dirty. Note: Regular cleaning is recommended to prevent issues with charging.
- Go to step 11.
Set the headphones to the charging case, connect the charging case using the supplied USB Type-C cable, and check the indicator of the charging case again.
- The indicator lights up in orange for more than 1 minute when the headphones are stored in the charging case
The remaining battery may be low. Charge the headphones for more than 30 minutes.- The indicator repeatedly flashes twice (or in 3 times) when the headphones are stored in the charging case
Go to step 12.- The indicator flashes slowly when the headphones are stored in the charging case
Go to step 11.- The indicator does not light when the headphones are stored in the charging case
Go to step 9.
Check if you can charge a different device with the same AC adapter or USB port.
Use the same AC adapter or the USB port on the computer to charge a different mobile device or product.- The mobile device or product can be charged
- Go to step 10.
- The mobile device or product cannot be charged
- The AC adapter or USB port may not be working. Contact the manufacturer.
Clean the charging port of the charging case, and check if the charging can be completed.
If any dust or dirt is in or around the charging port, the charging may not complete properly. Remove the dust or dirt with soft, dry cloth before charging.
- The headphones may be malfunctioning and service may be required.
Visit the Help Guide or view the following video on how to reset the headphones:
- The issue may have been caused by a temporary malfunction of the headphones.
- Go to the next troubleshooting step.
Note: After initialization, the headphones will return to the factory settings and all Bluetooth pairing information will be deleted.
