Article ID : 00349835 / Last Modified : 31/07/2025Print
Free Repair Programme for the ULT WEAR (WH-ULT900N) Headset – January 2025-2027
    Thank you for your continued interest in Sony products.
    We have found that cracks may occasionally develop on the rotating shaft at the joint between the headband and the headphone housing on a limited range of the ULT WEAR (WH-ULT900N).
    To address this concern, we are extending the warranty for affected products until January 31, 2027.
    We sincerely apologise for any inconvenience this may cause and appreciate your understanding and cooperation.
    Applicable model name
    •  ULT WEAR (WH-ULT900N)
    Applicable serial numbers
    Reference Table
    Destination CodeULT WEAR ColourApplicable Serial Number Ranges
    CE7
    (Europe)
     BlackFrom 1000001 to 1147155
     Off-whiteFrom 2000001 to 2043579
     Forest GreyFrom 3000001 to 3062933
    E
    (International -
    available at
    airports & tax-free zones
     BlackFrom 1000001 to 1046943
     Off-whiteFrom 2000001 to 2027901
     Forest GreyFrom 3000001 to 3025379
     How to check the model name and serial number
    Arrow pointing to ULT WEAR model name (YY2981) location inside the hanger of the left unit (A)
    Arrow pointing to ULT WEAR serial number location inside the headband of the left unit (B)
    • AThe model name (YY2981) is located inside the hanger of the left unit.
    • B: The serial number is located inside the headband of the left unit.
    Determine if your headphones are affected
    Check the image below to see if your headphones are affected.
    Look for cracks at the headband's rotating shaft, which may cause the headband housing to detach.
    ULT WEAR - Arrows pointing to potential cracks at the rotating shafts on both sides of the headphone headband
    Organise a free repair
    Once you've confirmed your headphones are affected and the serial number is eligible, please contact your nearest Authorised Service Centre (ASC):
    Free repair period
    Customers with affected serial numbers who experience this issue are eligible for free repairs until January 31, 2027.
