Article ID : 00382066 / Last Modified : 11/06/2026Print
    Unwanted noise is heard from the headphones (WF-1000XM6)
    Before you start
    If any dirt is left on the air holes of the earbuds, noise may occur. To prevent this, clean the vent holes on the earbuds.
    Air holes are just below the microphones of the earbuds
    Solution
    1. Select the situation when noise is heard:
      Noise is heard while walking, running, or shaking your neck
      When hair or fingers touch the microphone on the headphones, crackling or rustling noise may occur. This is normal, and not a malfunction. If you are bothered by the noise, turn Off the Noise Canceling or Ambient Sound Control.
      When the Noise Canceling or Ambient Sound Control is On, the vibration of walking, running, or shaking your neck may be transmitted from your body and cause noise. This is normal, and not a malfunction. To avoid this, turn Off the Noise Canceling or Ambient Sound Control.
      A cracking or popping noise is heard while or just after attaching the headphones
      This happens because air bubbles inside the earbuds get crushed and restored in response to movement that changes their shape. This is normal, and not a malfunction.
      Noise is heard when I push the headphones into my ears, or when I tap the touch sensor strongly
      This temporary noise can occur because of the Noise Canceling or Ambient Sound Control function and air-tightness of the headphones. This is normal, and not a malfunction.
      An echo is heard when I cover the headphones or built-in microphone with my hand
      An echo in this situation is normal and not a malfunction.
      Noise is heard when the surrounding ambient noise is loud, such as when I am in a station or near a construction site.
      When the Ambient Sound Control is On, the surrounding noises can be easily heard. Turn on the Noise Canceling function, or turn off the Ambient Sound Control function.
      White noise (a small electrical noise with continuous static sound) is heard
      This happens because of the Noise Canceling function. To avoid white noise, turn off the Noise Canceling function.
      Note: If the white noise is heard during a phone call, refer to the article The noise canceling function does not work or white noise is heard during a call on the headphones.
      A beep sound is heard while playing music
      Go to step 7.
      Noise is heard or sound is distorted while using the headphones in a crowded place
      Using the headphones in a crowded place such as on a train or busy road, nearby devices may interrupt Bluetooth communication and cause sound interruptions, interference, or noise.
      If the headphones are connected with LE Audio, switch back to Classic Audio only (conventional connection method) in the LE Audio connection setting for headphones. If the issue is not resolved after that, or you are not connecting with LE Audio, switch the sound quality mode to Priority on Stable Connection.
      Noise is heard while talking on the phone
      Go to step 2.
      None of the conditions listed
      Go to step 6.
    2. If noise is heard during a phone call, select the appropriate situation:
      The noise occurs in my voice
      Go to step 3.
      The noise occurs in the other person's voice
      Go to step 7.
    3. Fit the headphones to your ears firmly.
      If the earbuds are not worn properly, do not fit your ears, or the air-tightness is insufficient, the phone call quality may decrease. To maintain the quality, consider these factors:
      • Make sure that headphones are worn properly
      • Make sure that the earbud tips are firmly and completely attached. If you are using the optional earbuds (EP-NI1010), lightly turn over the earbud tips to make sure that the sound output hole is completely covered by the earbud tip.
      • Select the earbuds that best fit with your ears. Measure the air-tightness of the earbud tips and find the optimal size of earbud tips using the Sony | Sound Connect app
      For additional details, refer to the How to wear the headphones properly and select the most suitable earbud tips article.
      The issue is resolved
      The size or fitting conditions may have affected the Noise Canceling function.
      The issue is not resolved
      Go to step 4.
    4. Try speaking louder.
      The noise reduction function may have been the cause. When you speak quietly, the headphones may detect your voice as noise.
      Go to step 5.
    5. Use the headphones in a quieter place.
      The ambient sound may have been the cause.
      Go to step 7.
    6. Turn off the Adaptive Sound Control function.
      When the Adaptive Sound Control is set to On, the headphones detect your action (running, walking, etc.) and automatically switches the settings of the Noise Canceling function to Ambient Sound Control. To make maximum use of the Noise Canceling function, follow these steps to set the Adaptive Sound Control to off, and adjust the Noise Canceling or Ambient Sound Control manually.
      Note: If the Adaptive Sound Control is set to On, the Noise Canceling is adjusted and Adaptive Sound Control is activated according to your action.
      1. Turn off the Adaptive Sound Control.
        1. Connect the headphones and smartphone via Bluetooth, and then launch the Sony | Sound Connect app.
        2. In the My Device tab, check the Adaptive Sound Control status. If the status shows other than Off (Staying, Walking, etc.), select right arrow on the right side of the Adaptive Sound Control menu.
        3. Turn off the Adaptive Sound Control.
      2. Select Noise Canceling to turn the setting On.
      The headphones settings were the cause of the issue.
      Go to step 7.
    7. Try the following procedure:
      1. Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
      2. Restart the connected device.
      Go to step 8.
    8. Reset (restart) the headphones.
      Refer to the How to reset or initialize the WF-1000XM6 article or view the How to reset video below:
      If your headphones model does not appear in the device list of the playback device after the reset, turn off the Bluetooth setting in the device and turn it on again, or leave the Bluetooth setting once and return to try the connection again.
    9. Initialize the headphones.
      Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
