Article ID : 00109945 / Last Modified : 06/04/2026Print
    How to pair Bluetooth headphones with a Bluetooth source device
    WF-SP700N, WF-1000X
    Select another model
    Step 1. Enter the headphones into pairing mode
    1. Place the headphones into the charging case.
    2. Remove the left unit from the charging case.
    3. Press and hold the button on the left unit for at least 7 seconds. The indicator flashes blue and red alternately. If you put on the headphones, you will hear a notification sound and the voice guidance saying Bluetooth pairing from the left unit.
      Note: If the pairing is not finished within 5 minutes, the pairing mode on the headphones is canceled. If this happens, place the headphones into the charging case again and start the operation from the beginning.
    Step 2. Operate a device and complete the pairing
    Select your source device from the following list to confirm the pairing procedure:
    Note: Not all Sony Android TVs can be used with Bluetooth headphones or speakers. Verify your TV supports Bluetooth using the article Can I use Bluetooth headphones, speakers, and soundbars with my Android TV or Google TV?
    If the issue is not resolved
    If the issue is still not resolved, refer to the article Troubleshooting Bluetooth pairing issues.
