Article ID : 00372965 / Last Modified : 25/03/2026Print
Getting started with the Sony | Sound Connect app
    Personalising your sound profile
    In the Sound Connect app, you can customise different audio and system settings to enhance your listening experience, including:
    • Adaptive Sound Control
    • Ambient Sound Control
    • Noise Canceling
    • Equalizer (EQ)
    • 360 Reality Audio
    • Bluetooth Connection Quality
    • Voice Assistant settings
    Illustration of a woman wearing headphones in a city scene with people walking in the background.
    Downloading the app on your smartphone
    For Android users
    Available on Android 11.0 or later.
    For iPhone users
    Available on iOS 17.0 or later.
    *The Sony | Sound Connect app is compatible with select Sony products.
    See the list of supported models
    Navigating the Sony | Sound Connect app
    In this video tutorial, we'll show you how to customise the sound settings and access key controls and features in the Sony | Sound Connect app (formerly Sony | Headphones Connect).
    Switching between Noise Canceling and Ambient Sound
    With Adaptive Sound Control, you decide how much ambient sound you want (or don't want) to hear, whether you're at home or on the go.
    • Noise Canceling: Reduces ambient noise for a quieter listening environment
    • Ambient Sound: Filters in as much or as little surrounding noise as you want
    Before-and-after style illustration showing a headphone listener in a quiet city background (Noise Canceling enabled) versus a busier street with cars and people (Ambient Sound enabled).
    Adjusting the Equalizer settings
    Use the Equalizer to adjust frequency levels and tailor the sound to your preferences or what you’re listening to. You can make it:
    • Warmer and more relaxed (soft, mellow sounds)
    • Brighter and more energetic (think crisp instrumentals and EDM vibes)
    • Fine-tuned to emphasise vocals, bass, treble, and more
    Illustration of a person selecting music icons, with the Equalizer screen showing the “Treble Boost” preset.
    Experiencing 360 Reality Audio
    Immerse yourself in a three-dimensional sound field with concert-quality vocals, instruments, and sound effects. With 360 Reality Audio, you can:
    • Create a personalised hearing profile based on your unique ear shape
    • Save your hearing profile to your headphones for future use
    • Link your profile to supported streaming apps for optimised comfort and convenience
    Illustration of a woman in profile with sound waves and concentric circles around her ear.
    Revisiting your favourite artists and listening activity
    Check the Discover tab for a recap of your listening history and stats, including:
    • Your top tracks and playlists
    • Your listening time and locations
    • Badges you've collected
    Illustration of Sound Connect activities showing listening scenes (Walking, Night time, PC time) and a 360 Reality Audio badge.
    Adding the Sound Connect widget to your home screen
    You can easily check the status of your earbuds or headphones at a glance — without opening the app.
    To add the Sony | Sound Connect app widget:
    1. Press and hold an open space on your home screen.
    2. Select Widgets from the menu.
    3. Scroll and tap Sound Connect.
    4. Move the widget to your desired position.
    Smartphone home screen showing a Sound Connect widget with headphone model, battery level, Adaptive Sound Control disabled, and Equalizer status.
    Enabling automatic software downloads
    Turn on automatic downloads to get important app updates as soon as they’re available.
    To enable this feature:
    1. In the My Device tab, find and tap Device settings.
    2. Tap the System tab at the top of the screen.
    3. Toggle Download software automatically on.
    4. Tap the down arrow to expand the download setting options.
    Sound Connect setting screen with “Download software automatically” enabled and download options listed.
    Backing up your important data
    Back up and restore your saved settings on any signed-in device, including Adaptive Sound Control, 360 Reality Audio, and automatic software downloads.
    To back up and restore your data:
    1. Tap the Menu tab at the bottom of the screen.
    2. Find and tap Backup and restore settings and data
    3. Tap BACK UP NOW or RESTORE NOW and follow the on-screen instructions.
    Cloud upload icon surrounded by small feature icons, representing backup and sync.
    *Features and menu layout may vary by model and country/region.
