Article ID : 00234104 / Last Modified : 19/01/2026Print
    [360] Can I use and set the Equalizer and Surround (VPT) settings when I listen to 360 Reality Audio tracks?
    Yes, you can set both Equalizer and Surround (VPT).
    Nevertheless, Sony recommends that you turn off the Surround (VPT) setting when you listen to 360 Reality Audio tracks.
