Article ID : 00286314 / Last Modified : 10/02/2026Print
Which Sony audio products can use the exclusive features of BRAVIA TVs?
    Note:  Make sure your TV and other audio device have the latest software update. You can install the latest software update for your TV model or other Sony audio devices from the Sony Support website. For how to update your TV, refer to the How to perform a software update article for more information.
    Supported models for each feature are as follows:
    What is BRAVIA™ Acoustic Center Sync?
    When you connect a BRAVIA XR TV to a Sony soundbar, the soundbar reinforces the centre speaker channel for clearer and fuller vocals. Sound perfectly matches on-screen action for a truly immersive experience.
    The BRAVIA™ Acoustic Center Sync or S-Center speaker allows you to use the TV as a center channel speaker in a multi-channel setup.
    What is Voice Zoom 3?
    This feature uses AI technology to catch even the smallest dialogue sounds and automatically adjusts them so you can hear conversations clearly.
    What is Effortless control with BRAVIA TV?
    Because of an integrated user interface, soundbar settings automatically appear on the BRAVIA TVs Quick Settings menu to easily control sound and volume.
    What is 360 Spatial Sound Personalizer?
    Tailor your Dolby Atmos® experience by combining our SRS-NS7 wearable speaker with BRAVIA XR™ for spatial surround sound.
    With certain Sony headphones, you can also enjoy the simulated surround of 360 Spatial Sound using a separately sold Wireless Transmitter (WLA-NS7).
