Article ID : 00064411 / Last Modified : 25/05/2022Print
    What is the maximum communication range of the Bluetooth connection?
    The range of the Bluetooth connection is approximately 30 feet (10 meters). However, maximum communication range will vary depending on obstacles (person, metal, wall etc.) or electromagnetic environment.
    NOTE: Not all Sony audio devices are supplied with Bluetooth capability. To see if your device has Bluetooth capability, check the supplied manual.
