Article ID : 00285304 / Last Modified : 07/10/2024Print
Noise is heard from the LinkBuds.
    Before you start
    Update the headphones' software to the latest version. Doing so may resolve the issue. Perform the update before proceeding.
    Solution
    1. Select the situation that best describes when the noise occurs:
      While playing music
      Go to step 5.
      While talking on the phone
      Go to step 2.
    2. Select the device that you are using:
      Computer
      Go to step 3.
      Something other than a computer (such as a smartphone etc.)
      Go to step 4.
    3. Check the following:
      • If the noise occurs with your voice, the ambient sound may have been the cause. Try speaking louder, or use the headphones in a quieter place.
      • If you use the computer's built-in microphone, the noise may be heard with your voice. For details on how to change the computer's settings, refer to the When the headphones are connected to a computer there is no sound or the microphone does not work article.
      • If the noise occurs with another person's voice, the network communication may be unstable. Use the headphones near the computer to reduce the interference.
      The issue is resolved
      The ambient sound or the computer's settings may have been the cause.
      The issue is not resolved
      Go to step 5.
    4. Try speaking louder, or use the headphones in a quieter place.
      The ambient sound may have been the cause.
      Go to step 5.
    5. Set the headphones in the charging case, close the lid, wait for a few seconds, and then wear the headphones again.
    6. Try the following procedure, and check if the issue is resolved.
      1. Reset (restart) the playback device.
        Since the playback device may be temporarily malfunctioning, turn off the device once, and turn it on again.
      2. Delete the Bluetooth device information of your playback device.
        For details on how to delete the Bluetooth device information, refer to the How to delete the Bluetooth device information of your playback device article.
      3. Refer to the appropriate article to perform the pairing again:
    7. Reset the headphones.
      Refer to the Help Guide or view the How to reset video:
    8. Initialize the headphones and pair them with the playback device again.
      1. Initialize the headphones.
        Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
        Visit the Help Guide or view the How to initialize video:
      2. Refer to the appropriate article to perform the pairing again:
      The issue may have been caused by a temporary malfunction of the headphones or the playback device.
    Go to the Headphones Troubleshooting Guide
