Article ID : 00250876 / Last Modified : 11/06/2026Print
    How to care for your headphones (WF-**, WI-** Series)
    If the earbuds are not well-maintained and foreign substances (such as dust or earwax) build up, the volume may seem lower than usual or not come out at all, they may not charge properly, or the water resistant or dust proofing performance may be affected. We recommend caring the headphones regularly to prevent these issues.
    IMPORTANT:
    Refer to the appropriate article for the following models:
    How to care your headphones
    1. Remove the earbuds
    While holding down the unit, twist and pull to remove the earbuds.
    Note: Do not pinch the end of the earbud when removing it.
    2. Care your headphones
    Note for WF-SP900: For how to care your headphones after using them in sports such as swimming in a poor or ocean, refer to the Help Guide.
    Drain the sound output holes (for water resistant or dust proofing models only)
    If water remains in the sound output holes, the sound may become muffled or completely inaudible. If this is the case, remove the earbuds, position the sound output holes facing downward, and shake several times to get the water out.
    • Clean the charging port or USB port cover
      For Truly Wireless headphones
      If foreign substances, sweat or moisture is left on the charging port, wipe it off immediately and let it dry at room temperature. Otherwise, the charging function may be affected or not be possible at all. Be sure to regularly clean the contact points of the charging case and headphones using a soft cloth or cotton swab.
      • Contact points on the charging case:
        Image showing the charging ports located in the center of the charging case as A
      • Contact points on the headphones:
        Image showing the charging ports located on the top of the back of the headphones' housing parts
      Clean the contact points on the earbuds using a cotton swab or dry, soft cloth.
      image cleaning the charging ports inside the headphones
      image cleaning the charging ports on the back of  the housing ports
      For In-Ear headphones
      If perspiration, water, or moisture is left around the USB port cover for In-Ear headphones, wipe it off immediately and let it dry at room temperature. Otherwise, the charging function may be affected or not be possible at all.
    • Clean the earbuds
      If the earbuds become dirty, gently wash them by hand using a neutral detergent. After cleaning, thoroughly wipe off any moisture.
    • Clean the dirt outside of the headphones
      When the outside of the headphones is dirty, wipe it with a soft dry cloth. If it is extremely dirty, wipe them with a cloth that has been wrung tightly, dampened with a dilute solution of neutral detergent.
      Note: Do not use solvents such as thinner, benzene, or alcohol, as they may damage the surface.
    • Clean the sound output holes
      With a cloth dampened with water and wrung tightly, clean the mesh of the earbuds (the parts where sound comes out) to remove dirt, earwax, or anything that may accumulated, being careful not to accidentally push dirt or debris into the earbuds.
      Note: If the sound output holes are covered with mesh, do not rub the mesh too hard. Otherwise, the mesh may peel off or get torn.
    • Clean the vent holes (For WF-1000XM6)
      • Using a tightly wrung out water moistened cloth, wipe off any dirt, including earwax, in the vent holes of the earbuds.
        Air holes are just below the microphones of the earbuds
      • Remove the dirt without pushing it into the earbuds deeply.
      • If dirt is already lodged in the vent hole and cannot be removed using the above methods, use a dust-cleaning gel or a clean brush.
        • When using a dust-cleaning gel, press it against the vent hole to remove dirt.
        • When using a brush, gently sweep the surface to remove dirt.
  • Drain the microphone holes (for water resistant or dust proofing models of Truly Wireless headphones only)
    Turn the microphone hole downward and gently tap it about 5 times towards a dry cloth. Make sure that any water drops are not left in the microphone hole, or it may cause corrosion.
    If perspiration, water, or moisture is left on the charging port (around the USB port cover for In-Ear headphones), wipe it off immediately and let it dry at room temperature. Otherwise, the charging function may be affected or not be possible at all.
  • 3. Attach the earbuds
    Firmly reattach the earbuds completely, making sure the earbuds are not loose or skewed. Once the earbuds are attached, check to see if the headphones work properly.
    Tips to keep the headphones in good condition
    • After cleaning the headphones, be sure to set the headphones in the charging case, and close the lid.
    • Be aware that even if your headphones are water resistant or dust proof, the charging case is not. Make sure the headphones are completely dry before putting them in the charging case.
    • If you start charging with water or moisture left on the headphones, that water or moisture enters inside the charging case, which can cause a short circuit of the internal components, or corrosion of the headphones and/or charging case.
    • Do not leave the headphones in a cold environment, as any water or moisture left on the headphones may freeze. To prevent malfunction, make sure to wipe off any water or moisture after use.
    • Make sure the USB Type-C® port cover (or the Micro-USB port cover) is closed securely when using the headphones.
      Related article: Safeguard the WI-SP510 and avoid liquid damage by sealing the USB-cover
