Article ID : 00285264 / Last Modified : 20/01/2026Print
    There is no sound, or sound is only heard from one side of the headphones. (WF-SP800N)
    Before you start
    Update the headphones' software to the latest version. Doing so may resolve the issue. Perform the update before proceeding.
    Solution
    1. Check if the indicators flash when the headphones are removed from the charging case.
      The indicators flash
      Go to step 3.
      The indicators do not flash
      Go to step 2.
    2. Charge the headphones and the charging case, and check if the headphones turn on and the sound is heard from the headphones.
      The headphones turn on, and I can hear sound from the headphones
      The cause may have been a low battery. Wait until the headphones are fully charged.
      The headphones turn on, but I cannot hear sound from the headphones
      Go to step 3.
      The headphones do not turn on
      Charging cannot be done properly. Refer to the The headphones do not charge article.
    3. Reconnect the headphones and the device.
      1. Set the headphones into the charging case, and close the lid.
      2. Remove the headphones, and connect with the device again.
      The Bluetooth connection may have been temporarily unstable.
    4. Turn up the volume on the connected device.
      The issue may have been caused because the volume was set too low.
      Go to step 5.
    5. Reset the headphones.
      Visit the Help Guide or view the How to reset video:
    6. Initialize the headphones.
      Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
      Visit the Help Guide or view the How to initialize video:
    7. If you have a different smartphone, Walkman, or other device, perform a Bluetooth pairing with the headphones and one of these other devices, then check if sound is heard from the headphones.
      The playback device that was initially connected may be malfunctioning. Consult the manufacturer of the device.
    Go to the Headphones Troubleshooting Guide
