Article ID : 00254730 / Last Modified : 20/01/2026Print
Unexpected volume changes when connecting to an iPhone
    Headphones volume may shift to the Ringer and Alerts volume level when:
    •  the lock sound on the iPhone is played.
    • a typing sound occurs using the iPhone keyboard.
    You can solve this by disabling the Lock Sound and Keyboard clicks functions:
    1. On the Home Screen, select Settings.
    2. Select Sounds & Haptics.
    3. Change the Lock Sound function and Keyboard Clicks function to OFF.
