Article ID : 00109945 / Last Modified : 06/04/2026Print
How to pair Bluetooth headphones with a Bluetooth source device
    WF-XB700
    Select another model
    Step 1. Enter the headphones into pairing mode
    • When you pair the headphones with a device for the first time or after initializing, the headphones automatically enter the pairing mode when you remove them from the charging case. If you put on the headphones, you will hear a notification sound and the voice guidance saying Bluetooth pairing from the left unit.
    • To pair the headphones with a second device, press and hold the buttons on both units for at least 5 seconds. The indicator on the left unit flashes blue twice in a row If you put on the headphones, you will hear a notification sound and the voice guidance saying Bluetooth pairing from the left unit.
      Note: If the pairing is not finished within 5 minutes, the pairing mode on the headphones is canceled. If this happens, place the headphones into the charging case again and start the operation from the beginning.
    Step 2. Operate a device and complete the pairing
    Select your source device from the following list to confirm the pairing procedure:
    Note: Not all Sony Android TVs can be used with Bluetooth headphones or speakers. Verify your TV supports Bluetooth using the article Can I use Bluetooth headphones, speakers, and soundbars with my Android TV or Google TV?
    If the issue is not resolved
    If the issue is still not resolved, refer to the article Troubleshooting Bluetooth pairing issues.
