Connect your headphones to two devices simultaneously (multipoint connection)
When you connect headphones to a device, the music playback (Media audio) and the phone call function (Call audio) are connected simultaneously. Most headphones allow multiple Bluetooth® connections to audio devices; however, to switch sources, you need to go into the Bluetooth settings, disconnect the current source, and then connect the source you want to use with the headphones.
If your headphones support a multipoint connection, you can switch easily between two audio sources without going through the standard Bluetooth reconnection process.
Before you start
- Multipoint connection works with only two devices at a time.
- A third device can be connected through Bluetooth, however, the Bluetooth connection with the last device that played music will stay connected, and the second device will be disconnected for the third device to establish the Bluetooth connection with the headphones.
- Download the Sony | Headphones Connect app on one of the devices and make sure it has the latest update.
- Both source devices must support Bluetooth capability.
- When pairing the headphones with any device, make sure to select the actual model name. For example, select WH-1000XM4, rather than LE_WH-1000XM4 on the source device.
- It may take up to one minute before WH-1000XM4 appears on the screen.
How to use the multipoint connection
The steps may vary depending on the devices that you want to use. Follow the instructions according to the devices the headphones will be paired to.
Walkman® player (or other music players) and a smartphone
Android phone and an iPhone® mobile digital device
Related articles
- How to connect your Bluetooth headphones to a laptop/desktop computer
- How to pair Bluetooth headphones with a smartphone
- How to pair a Walkman player with a Bluetooth audio device
- What is Bluetooth pairing?
Trademarks and Logos for Google LLC and Related Company
*iPhone, iPad, Mac, AirPlay, and HomeKit are trademarks of Apple Inc., registered in the U.S. and other countries.
