Article ID : 00257871 / Last Modified : 20/01/2026Print
    The volume cannot be adjusted using In-Ear or Headband type headphone
    This page will help you troubleshoot when the volume cannot be adjusted using In-Ear or Headband type headphones:
    1. Check to see if you can adjust the volume using the headphones:
      Adjust the volume by using the touch sensor control panel or pressing the +/- buttons of the headphones. For details, refer to the headphones Help Guide.
      The volume can be adjusted.
      Operate the headphones properly according to your model.
      The volume cannot be adjusted.
      Go to step 2.
    2. Check to see if you can adjust the headphone volume using the Sony | Headphones Connect app:
      NOTE: If your headphones do not support Sony | Headphones Connect app, go to step 3.
      List of compatible devices (Sony | Headphones Connect)
      To adjust the volume using the Sony | Headphones Connect app, move the slide bar at the right side of the speaker icon in the Status tab.
      If your headphones support Sony | Headphones Connect app, you can adjust the volume by operating the app.
      Go to step 3.
    3. Check to see if you can adjust the volume by operating the connected device:
      Try adjusting the volume on the connected device. For how to adjust the volume, refer to the device manual or support site.
      NOTE: Depending on the connected device, the volume may not sync with the headphones. If you cannot get the desired volume by adjusting the headphones volume only, adjust the volume on both the headphones and the connected device.
      You may need to adjust the volume depending on the device or situation.
      Go to step 4.
    4. Check to see if you can adjust the volume by operating the app.
      If the app you are using has the volume settings, try adjusting the volume by using those settings.
      The issue was caused by the volume settings on the app.
      Go to step 5.
    5. Check to see if you can adjust the volume after resetting the headphones:
      The method for resetting the headphones differs depending on the model. For details, refer to the headphones Help Guide.
      The issue was caused by a temporary malfunction of the headphones.
      Go to step 6.
    6. Check to see if you can adjust the volume after initializing the headphones:
      NOTE: When you initialize the headphones, the headphones return to the factory settings and deletes all Bluetooth pairing information.
      The method of initializing the headphones differs depending on the model. For details, refer to the headphones Help Guide.
      The headphones may be malfunctioning and Service may be required.
