How to set the default music app in the Google Assistant app
Set the default music app for Google Assistant
Note: Due to the changes Google has made to the Google Assistant feature, linking headphones to the Google Assistant app for iOS has been discontinued.
Follow these steps to set the default music app in the Google Assistant app:
- Press and hold the smartphone's Home button to start the Google Assistant app.
- Tap
on the upper right side of the screen.
- In the upper right corner of the screen, tap
(three vertical dots), then tap Settings.
- Scroll down and tap Music.
- Select the desired app.
