Article ID : 00242303 / Last Modified : 20/01/2026Print
The screen doesn’t turn off when I close the cover
    Make sure that you have selected the correct cover type in Settings.
    1. Find and tap Settings → Display → Cover selection. You may find the item under Advanced.
    2. Tap Flip cover → OK.
