Article ID : 00243052 / Last Modified : 20/01/2026Print
I can't remove the cover from my mobile device
    Remove the cover from your device as shown below.
    • XQZ-CVAT, XQZ-CVAU, SCVI10, SCTI30, SCTH70, SCSH70
      • Detach the bottom right corner of the device from the casing, then detach the bottom left corner.
    • SCSI10, SCSI20, SCSH30, SCSH40
    • Detach the upper right corner of the device from the casing, then detach the bottom right corner.
