My camera displays an error code beginning with E, C or System error
The steps to solve this issue differ depending on the displayed error.
C:13:01
Error is displayed when you are using the internal memory
This error occurs in the internal memory. Follow these steps:
- Turn off the camera.
- Turn on the camera again.
Note: If the situation is not improved, format the internal memory after backing up the stored data.
WARNING! There is a risk of data loss. When you format the internal memory, all stored images will be deleted, including protected ones.
Error displays when using a memory card
This error occurs in the memory card. Follow these steps:
- Insert and remove the memory card several times.
- Check whether the memory card is supported by the camera. For more details on compatible memory cards, refer to the operating instructions supplied with the camera. Manuals are posted on the support website.
- Note: The error code “C:13:01” may be displayed when you record large amounts of data, such as when recording movies.
- Use another memory card.
- If you record and delete images repeatedly, the files on the memory card may become fragmented, and the recording may stop automatically.
- After backing up the stored data to your computer, format the memory card with the camera.
WARNING! There is a risk of data loss. When you format the memory card, all stored images will be deleted, including protected ones.
System error and Errors that start with C:32, E:41, E:61, E:62, E:91 or E:92
Follow these steps when C:32, E:41, E:61, E:62, E:91 or E:92 errors are displayed:
- Remove the battery pack.
- Attach the battery pack.
- After one minute, turn on the power of the camera.
Check the table below for other errors displayed on your camera:
Error Code | Possible Causes |
System error | Issue with the hardware |
C:32:01 | Issue with the hardware |
E:41:00 | Issue with Wi-Fi |
E: 61: 00 | Issue of the focus drive |
E: 61: 10 | Issue of the zoom driving part |
E: 61: 30 | Issue of the lens driving part |
E: 62: 02 | Issue of the image stabilisation |
E: 62: 10 | |
E: 62: 11 | |
E: 62: 12 | |
E: 62: 20 | |
E: 91: 01 | Issue of the flash unit part |
E: 91: xx | Issue of the flash unit part, battery recognition, etc. |
If the error isn't resolved after following the troubleshooting steps for the corresponding error listed in the table, service may be required.
