The firmware network update failed
If the network update does not succeed, try the following measures:
- For Blu-ray Disc players with the Quick Start Mode capability, change the Quick Start Mode setting to Off. Then perform the firmware update again.
- If a disc is inserted in the Blu-ray Disc player, remove the disc and unplug the player. Then perform the firmware update again.
- If the download continues to fail, the wireless connection may not be strong enough for the download process.
Refer to this additional information on how do I install firmware updates for my player .
