Article ID : 00078265 / Last Modified : 11/04/2022
How to view movies saved on a computer or a USB external HDD by Direct Copy function on a TV.
    To play back movies saved on a computer:
    1. Connect the camcorder to the computer and write back the movies to the camcorder using the PlayMemories Home software .
      NOTE: Only AVCHD, MP4 and XAVC S movies can be written back.
    2. Connect the camcorder to the TV by HDMI cable.
    To play back movies saved on an external recording medium:
    (Only for models with the Direct Copy function)
    1. Connect the camcorder to the external recording medium with the USB cable.
      NOTES:
      • A VMC-UAM1 USB Adapter Cable (sold separately) is required if a USB Adapter Cable is not supplied with your camcorder.
      • Use VMC-UAM2 (sold separately) if your camcorder is equipped with Multi Terminal.
    2. Connect the camcorder to the TV.
    3. Select the Play without copying option.
      NOTES:
      • Supply power to the camcorder using the AC Adaptor.
      • Some camcorders may not be compatible with the Play without copying function when connected to an external HDD.
