Article ID : 00156826 / Last Modified : 27/12/2017
How to set the Parental Control for Internet Video?
    Follow the procedure below to configure the Parental Control settings:
    1. Select Internet Video Parental Control in Parental Control settings.
    2. Press ENTER.
    3. Enter your four-digit password using the up or down buttons or the number buttons.
    4. Select OK.
    5. Press ENTER.
    6. Select the restriction level.
    7. Press ENTER.
    NOTE: The initial restriction level is No Restrictions. It is necessary to set the four-digit password in advance.
