How long is the battery life?
The battery life changes depending on the model and the settings. For details see below:
- RDP-V20iP
Approx. 5 hours of use - SRS-X7
When the NETWORK OFF/ON switch is OFF: Approx. 6 hours
When the NETWORK OFF/ON switch is ON: Approx. 3 hours - SRS-X11, SRS-X33, SRSXB2, SRS-X1, SRS-HG1
Approx. 12 hours of use - SRS-XB3
Approx. 24 hours of use
NOTES: -
- For models other than the above, refer to the manual supplied with the product.
- The actual battery life will vary depending on the temperature, the equalizer settings of the audio input device, etc.
