How to hear sound from a disc player, cable set-top box or satellite receiver through the speakers of the audio system
Follow the steps below to connect a disc player, cable set-top box, satellite receiver or other similar source device to the audio receiver or home theatre system
NOTE: Although there may be other methods, the methods provided below are the most common scenarios. For model-specific information about other possible connections and system settings, we advice to refer to the operating instructions supplied with the product.
HDMI cable:
HDMI offers many advantages over other connections, such as:
- HDMI transfers uncompressed digital audio and video for the highest, crispest image quality
- HDMI combines video and multi-channel audio into a single cable, eliminating the cost, complexity, and confusion of multiple cables currently used in A/V systems
- HDMI supports multiple audio formats, from standard stereo to multi-channel surround-sound
- Connect the HDMI cable to the HDMI OUT of the source device.
- Connect the other end of the HDMI cable to the HDMI IN on the receiver or home theatre system.
- Using a second HDMI cable to the HDMI OUT of the receiver or home theatre system.
- Connect the other end of the HDMI cable to an HDMI IN on the TV.
- Set the TV and the audio system to the HDMI input.
- From the Settings menu of the source device, set the Audio Output setting to HDMI.
- From the Settings menu of the source device, make sure that the HDMI settings match the capability of the audio system.
NOTE: Refer to the manual of the audio system and the source device for model-specific information regarding the various audio settings and capabilities.
Coaxial audio cable or Optical audio cable:
The following are some advantages of using an Optical audio cable or coaxial audio cable over other connections:
- An optical audio cable uses pulse light instead of electrical impulses which makes it less likely to suffer from interference.
- Both coaxial audio cables and optical audio cables support surround-sound for up to 5.1 channels of sound.
- Both coaxial audio cables and optical audio cables transfer a digital signal with a wider frequency bandwidth to provide superior signal transfer.
- Connect either the coaxial audio cable or optical audio cable to the COAX OUT or OPTICAL OUT of the source device.
- Connect the other end of the coaxial audio cable or optical audio cable to the COAX IN or OPTICAL IN of the receiver or home theatre system.
- Using one of the cables below, connect a separate video cable from the VIDEO OUT of the source device to the VIDEO IN on the audio receiver or home theatre system.
NOTE: If the receiver or home theatre system being used does not have a VIDEO OUT connection to send the signal to the TV, you can also make the video connection from the source device directly to the TV.
- HDMI cable
- Component video cable
- S-video cable
- Composite video cable
- HDMI cable
- Set the TV and the audio system to the input mode being used by the above connections.
- From the Settings menu of the source device, set the Dolby Digital and DTS settings to either Optical or Coaxial.
Composite audio video cable:
Some of the advantages of using an composite audio video cables are:
- This is the most common type of cable to make a stereo audio connection between components.
- This cable is typically found in the box with audio components
- Provides a stereo audio connection between components.
- Connect the composite audio and video cables to the LINE OUT on the source device.
- Connect the other end of the composite audio and video cable to the Line IN on the receiver or home theatre system.
- Connect a composite video cable from the VIDEO OUT of the receiver or home theatre system to the VIDEO IN on the TV.
- Set the TV and the audio system to the composite input.
- From the Settings menu of the source device, set the Audio setting or Downmix setting to Stereo.
