What is the purpose of the Image Database File?
The Image Database File is used to manage movie files on the Memory Stick PRO Duo media recorded with the camcorder. Without this file, the camcorder cannot record movies. Therefore, when using a new Memory Stick PRO Duo media, you should first format the media in the camcorder. Formatting the media in the camcorder will create the Image Database File. You will not need to create another Image Database File unless it becomes damaged or if the Memory Stick Duo media is formatted by a device other than the camcorder.
NOTES:
- Follow these steps if the The image database file is damaged.
- The Image Database File is not needed when recording still images.
