There is no sound when a Bluetooth (BT) device is connected to Blu-ray Disc Home Theater System
Check the following if there is no sound when a BT wireless device is connected to Blu-ray Disc player/ home theater system:
NOTE: Because each of these steps represents a possible solution to this issue, check the sound status after completing each step.
- Ensure that the Blu-ray Disc player/ home theater system is not too far from the BT device.
- Ensure that the system is not receiving any interference from a Wi-Fi network, other 2.4 GHz wireless device or a microwave oven.
- Verify the BT connection between Blu-ray Disc player/ home theater system and the BT device.
- Pair the home theater system and the BT device again.
- Keep the Blu-ray Disc player/ home theater system away from metal objects or surfaces.
- Verify that the BT function of the Blu-ray Disc player/ home theater system is selected.
- Adjust the volume of the BT device (the receiving device, such as a speaker or headphone).
- If the volume level is still too low, adjust the volume level on the Blu-ray Disc player/ home theater system.
