Article ID : 00155399 / Last Modified : 16/01/2026Print
How to pair the Blu-ray Disc player with a Bluetooth device
    Check the connection and settings by the following steps:
    1. Perform the following in your Bluetooth device:
      • Place the Bluetooth device within 1 meter from the player.
      • Set the Bluetooth device in pairing mode.
        NOTE: For details on setting the Bluetooth device in pairing mode, refer to the instruction manual supplied with the device.
    2. Perform any of the following when connecting to a device for the first time:
      1. Press BLUETOOTH button on the remote.
      2. Select Bluetooth Device option on the playback screen.
      3. Select Device List in BluetoothSettings.
      4. Press Image/Imagerepeatedly to select the device you want, and press ENTER.
        When the Bluetooth connection is established, the device name will appear on the TV screen.
    3. Perform the following if the Blu-ray player already has paired:
      1. Select Setup.
      2. Select Bluetooth settings.
      3. Check the Device list.
      4. Scan from this player and select your Bluetooth device.
