Article ID : 00092526 / Last Modified : 27/06/2019Print
    Is it possible to listen to music in High-Resolution quality by using the supplied headphones?
    You cannot use the supplied headphones to enjoy High-Resolution Audio sources at High-Resolution quality.
    Use headphones designed to support High-Resolution* to enjoy music at High-Resolution quality.
    * Sony products designed to maximize the sound performance of High-Resolution Audio have the Hi-Res AUDIO logo.
