Can I operate the camera while using the USB connection?
You cannot operate the camera while using the USB connection. Disconnect the camera from the device to operate it.
WARNING: There is a risk of data loss. Do not disconnect the camera if the access lamp is lit. The transmitting data or recorded data in the memory card may be damaged.
