Article ID : 00104457 / Last Modified : 08/01/2015
How can I enable Bluetooth and one-touch connection (NFC) on my smartphone?
    One-touch connection is not possible when the unit is already connected to another NFC compatible device. Please disconnect the device and reconnect it to the smartphone.
    Make sure that the Bluetooth signal is ON. The Bluetooth figure mark lights up or flashes on the display.
    After touching it, try to connect the device again according to the instructions on the smartphone's screen.
