Article ID : 00104950 / Last Modified : 09/01/2015
Is there any way I can improve the connectivity of the MirrorLink feature with my Nokia smartphone?
    You may improve the connectivity between your Nokia smartphone and the unit when using the MirrorLink feature by activating the following setting on your smartphone:
    • Go to "Settings"
    • Tap on "Connectivity"
    • Then, tap on "USB"
    • Finally, tap on "Nokia Ovi Suite"
