If you are experiencing MirrorLink connectivity issues between your Sony Xperia smartphone and the unit, you can try the following:
- Disconnect and reconnect the USB cable between your smartphone and the unit
Or, if the problem persists:
- Disconnect the USB cable, turn off your smartphone and turn it back on. Then, reconnect the USB cable between your smartphone and the unit
