Follow the steps below to re-pair the remote control.
- Remove the batteries from the remote control and reinsert them.
- Set Bluetooth settings in Settings to Off, then set it to On again.
- Press the HOME button on the remote control.
- Select Settings.
- Select Bluetooth settings in the Network & Accessories category.
- Select Bluetooth, then disable the function.
- Select Bluetooth again, then enable the function.
- If the TV and remote control are paired, unpair them.
Follow the steps below to check if they are paired.
- Select Settings.
- Check if the device information (ex: SONY TV RC MIC 001) of the remote control is displayed.
- If the device information of the remote control is not displayed, check step 4 below.
- If the device information of the remote control is displayed, use the following procedure to unpair.
- Select the device information of the remote control.
- Select Unpair.
- Select OK.
- Re-pair the remote control.
NOTE: There are two types of remote controls referred to in this answer. The microphone mark is printed on both types, as shown in this image.
[A] Type A (Touchpad Remote Control) [B] Type B (Remote control that supports voice recognition)
If the Remote Control is registered to a different TV, turn off that TV, and then follow the steps below to reregister your Remote Control to the desired TV.
When using Type A (Touchpad Remote Control), check the following.
When pairing using the IR Remote control
- Turn on the TV.
- On the IR Remote control, press the HOME button.
- Select Settings.
- Select Touchpad Remote Control settings in the Network & Accessories category.
- Select Pair Touchpad Remote Control.
- Select Yes.
- Follow the on-screen instructions.
When pairing without the use of the IR Remote control
- Turn on the TV.
- On the back panel of the TV, press the INPUT button for 7 seconds.
NOTE: The following image provides an example of the INPUT button.
NOTES:
When using Type B (Remote control that supports voice recognition), check the following.
- Turn on the TV.
- Select Settings.
- Select Voice Remote Control in the Network & Accessories category.
- Select Activate the
button. - Follow the on-screen instructions.
NOTE: Due to the restrictions of Bluetooth Low Energy, when the TV that contains the remote control’s pairing information remains ON, the registration will fail.
