Article ID : 00118966 / Last Modified : 16/01/2026Print
I cannot use the Touchpad remote control after doing a Factory data reset or after removing it from the Device list in the Bluetooth settings
    Follow the steps below to register the remote:
    1. Make sure that the batteries are properly inserted.
    2. Update your TV with the latest software .
    3. Press and hold the INPUT button on the TV for at least 5 seconds, and register the Touchpad remote from the screen that is displayed.
    NOTE: If the remote is still not working after following the steps above, you may have to initialise the Touchpad remote
